Deze lijst is niet bedoeld als spam
Ik heb er al een aantal onderdeelnummers in terug kunnen vinden
::::: RSC 172/182 (Some 197) :::::
ACC BELT 8200226493
ACC BELT TENSIONER KIT 7701477519
(Belt, Tensioner & Idler Pulley)
ACCELERATOR CABLE PH 1
- 7700427379 / OZ 7700815667
AC HOSE – 6000073635
AIRBAG (steering wheel)
172 – 8200432120
182 – 8200 432121
AIRBAG Sensor & Control unit - 8200375763 - 8200335431
AIRBAG – S RS module 8200621763
AIR BOX Complete - Ph 1 - 7700260096
AIR BOX Complete - Ph 2 - 7700114812
AIR BOX Complete - Ph 2 - 8200453864
AIR BOX Complete - Ph2V6 – 8200726367
AIR BOX BRACKET 77001147476 ??
AIR BOX BRACKET
- 8200141200
- 8200141202
- 8200141199
ALUMINIUM PEDAL ARMS
- clutch 8200083894
- brake 7700411238
- accelerator (rubber ) 8200699958
- accelerator (cruise) 8200699893
ALUMINIUM PEDAL PADS
- clutch 6000073658
- brake 6000073658
- accelerator 7701207692
AUDIO CONNECTOR KIT 197 - (7711426614)
AUDIO CONNECTOR RCA - 7711422890
BADGES
- Renault 7700817027
- Sport 6000068214
- Clio 7700849001
- RS emblem (197) 8200535890
BATTERY (Motrio) 8671016916
BATTERY (Renault) (SU)MF44 – can source
BATTERY SUPPORT MOUNT
BELL HOUSING (7701467626)
BONNET PROTECTOR F5166B6500AU
BONNET SEAL 8200085033
BOOT CENTRAL LOCKING SOLONOID
- (7701039565)
BOOT LOCK (8200060917)
Brake Master Cylinder
BRAKE (AIR) DUCTS
- 7711155482 (Drivers side)
- 7711155483 (Passenger side)
BUMP STOP RUBBER – 7700434126
BUMPER SECTION
- Black 8200083217
- Primed 7701062550
CAMBELT KIT / TIMING BELT
(no plugs) 7701476675
CAM SEAL SET front - 7701471629
CLEAR SIDE INDICATORS 8200257684 - each
CLOCK SPRING:
- Lucas 7701045278
- Valeo 7701045277
CLUTCH CABLE
172/182 ph1 & ph2– 8200699727
CLUTCH KIT - 7701476557
Clutch thrust bearing – 7700102781
COIL PACK 8200141149
CONTROL ARMS
- RH wishbone 8200257957- each
- LH wishbone 8200257956 - each
COOLANT ELF 5L – 7711428130
COOLANT Motrio 5L – 8671017367
COOLANT TEMP SENSOR – 8200561449
CRANK BOLT
CRANK PULLEY
- (Harmonic Balancer) 8200386460
CV BOOT – 7701207397
CV JOINT
- 7701471522
- 7701056850 – 30 TEETH
- 7700113959 – 29 TEETH
Decal Kit:
- 8200766115 (Black)
- 8200766120 (Grey)
- 8200749304 (White)
DECAL 197 – F1
- Front 8200771868
- RH side 8200771876
- LH side 8200771871
- Rear 8200771867
- Rear window 8200786127
- Top 8200771879
DECAL KIT 197
- 7711421154
DE-MISTER SWITCH 8200060037
DEPHASER PULLEY 8200782671
DOOR HANDLE
- 197 external LHS 7701478162
DRIVESHAFT
- RH: 8200257767
- LH: 8200257766 8200372167
DRIVESHAFT - Remanufactured
- DS 7711135155
- PS 7711135878
DRIVESHAFT BOOT
- RH inner 7701471522 PH 2
- RH inner 7701207822 PH 1
DUST COVER for Strut Piston 7700434126
EXHAUST COMPLETE (182)
- cat 8200335385
- centre section 8200373725
- back box (silencers)8200373726
EXHAUST MANIFOLD
- 182 Cup 4-2-1 (8200444565)
ENGINE COVER – 8200097512
ENGINE COVER oil access – 8200186031
ENGINE MOUNTS –(NB: NEED VIN)
- top rh 6000073669
- m torsion 8200103802 (twisted)
- gearbox 7700434628
- lh front 8200089697
- lh front 7700795688
Exhaust SEAL/Flange Gasket Kit 6000073668
EXHAUST MOUNT rear 7700424339
EXHAUST MOUNT middle 7700424341
EXHAUST TIP HEATSHIELDS for 182
- 8200351433
EXTERIOR TEMP SENSOR
- (without the mirror) 7700773858
Flywheel
FLOOR MATS Clio Ph3
FOGLIGHTS
PH 2
- Clear 8200002469/ 70
- Textured 7701045717/ 8
PH1
- Textured 7701205664/ 5
FOGLIGHT - each
FRAME SLIDERS/Seat Runners 7701207202
FRONT BUMP STOP RUBBERS 7700434126
FRONT BUMPER BAR RSC – 7701473753
FRONT CAMSHAFT SEAL KIT – 7701471629
Front lower Timing Belt Cover – 7700113619
FRONT PADS 7701209380
FRONT PADS (Motrio) 8671016177
FRONT PADS – Ferodo DS2500
FRONT ROTORS - the pair 7701207829
FRONT ROTORS (Motrio) 8601005975
FRONT ROTOR BOLTS – 7703004176 EACH
FRONT SHOCK ABSORBERS each
- 172 Cup Ph 1 - standard 6000073526
- 172 Ph 2 - normal 8200104116
- 182 Cup - extremes 8200342845
- 197 – sport 8200677288 - 440614 RS
- 197 - extremes 8200682323 Cup
FRONT SPLITTER 8200248910
FUEL PUMP – 8200683203
GARMENT CARRIER 7711219816
GEARBOX
– 7711135025 recondition no esp
- 7701723135 esp
- 7701715391 non esp
GEARBOX ‘Reverse light’ switch 7700422630
GEAR LEVER GAITOR/BOOT
GEAR SHIFT KNOB - 6000073675
197 Hands Free Phone Kit: 7711424854
HAZARD LIGHT BUTTON 8200442723
HEADLIGHTS – each 7701054075 /062 (172)
HEADLIGHTS – each 7701057661 /657 (182)
HEADLIGHTS – each 7701051794 /3
HEADLIGHTS non xenon - each 7701045177/6
HEADLIGHTS Protectors – each
- ph 1 B6310B6500AU
- ph 2 B6310B6510AU
HEADLAMP SERVO MOTOR 7701207033
- comes with Electronic Control Unit
PART NO 7701207033
HEADLIGHT WASHER JETS -each 7701207168
HEAD PLUGS
- 7700274026
- 7700106271
IGNITION LEADS Ph1 172 cup - 8200334440
INJECTORS 8200207049 EACH
INJECTORS SEAL 7701206043 EACH
INLET MANIFOLD (197) 8200504232
INLET COLLECTOR (197) 8200717383
INTERIOR PERSONALISATION PACK
- Carbon Fibre 7711420049
INTERIOR TEMP SENSOR 8200093290
KIT ADJUSTERS – 7701206434 (per side)
Lower timing belt cover – 7700113619
Mats Phase 2: 7711425548
Mat – Boot (rubber/carpet) Ph 2: 7711219951
Mats Phase 3: 7711425549
MIRROR HOUSING / BODY (Black)
- 8200071401 Drivers side
- 7700435863 Passenger side
MIRROR GLASS
- 7701040255
- 7701051274 (AU)
MIRROR BACK COVER - 7701471857
OIL
- Renault ELF 5w40 – 7711275973
- Motrio 5w40 5 litres - 8671013784
NUMBER PLATE LIGHT
- bumper 7700410754
- boot 7700433414
OIL PACK Ph1 172 cup - 8200141149
POP RIVETS - 7703072047 - each
POWER STEERING HOSE
- 6000073548 back of pump 2 reservoir
- 6000073688 pump 2 steering rack
- 7700115236 rack 2 pump
- 7700435692 or 413763 pressure switch
POWER STEERING PUMP 8200234212
QUARTER PANEL
Left front:
- front 6000073747
- rear 6000073749
R5 GTT Radiator
- 7701414002
RADIATOR 172/182
- REFURBISHED... 7701352903
- NEW...7700417175
RAIN SENSOR
REAR BUMPER
Rear camshaft plugs –
(7700106271 + 7700274026)
REAR LIGHTS / tail-light
- Crystal 7711225810 (each)
- Standard (each)
REAR PADS the set 7701207034
REAR PADS the set - Motrio 8671016190
REAR ROTORS the pair 7701204901
REAR SHOCK ABSORBERS
- 172 - normal 8200662257
- 182 - normal 8200360041
- 182 - extreme 8200342846
REAR STORAGE TRAY – 7701416299
REAR WIPER BLADE - 7701410155
REAR WIPER BLADE ARM - 7701045207
RECARO SEATS (R27)
- Top (7701070579)
- Bottom (7701070579)
RECARO SEATS (UK TROPHY)
- Complete (7711421156) each
RECEIVER DRYER (7700836314)
REMOTE RESERVOIR DAMPERS Trophy
- REAR SHOCKS each
- FRONT SHOCKS each
Right front quarter panel 7701472418
ROOF BARS KIT- Ph 2:
- Aluminium 5dr 7711219723
- Aluminium 3dr 7711219722
- Steel 7701410519
ROOF BARS KIT- Ph 3:
- 7711221420
SEATS (172 / 182)
- lower cushion 7701715738
- back cushion 7701209295
- back cover 7701057745
- lumbar support assembly – 7701207213
SEATBELT BUCKLE RH 8200703361
SEAT-TILT OPENING CABLE 7701058771
SEAT-TILT ADJUSTER CABLE 7701207474
SPEEDO SENSOR 7700418919
SPOILER
- 7701474864 (CUP) – may not need LED light
- 8200140895
- 7701410747
SPRINGS (172) - FRONT
- Normal 8200342859 each
- Extreme 8200342860 each
SPRINGS (172) - REAR
- Normal
- Extreme 8200342862 each
SPRINGS (172) – SET of 4
SPROKET KIT – 7701471629
(includes seals, nuts & bolts)
STEERING ANGLE SENSOR
STEERING HUB ASSEMBLY - 7701051757
STEERING RACK BOOTS
30mm OR 40mm (diameter of shaft) – JTEKT/ KOYO/ SMI
- 30mm 7701473652
- 40mm 7701469496
OR
- TRW
-- DS 7701471141
-- PS 7701469486
STEERING RACK ENDS
STEERING WHEEL Ph 2 - 8200155961
STEERING WHEEL Ph 1 Suede
- 7700849836 same as below
- 7700437547 AUS
- 7711160037 Sabelt - ph 1 CUP - RACE
STEERING WHEEL - THUMB PADS
STUB AXLE (172) rear – 8200104117
STRUT BRACE – rear 8200905098
SWAY BAR BUSHES (Front)
- 7700847383 each
- 7700784171 each
SWAY BAR RUBBERS 7700799404
SWITCH PANEL – 8200084023
STEERING WHEEL CONTROL 8200060038
STEERING WHEEL INSERT (RenaultSport)
- 8200749306
SUNGLASS HOLDERS - 8200035039
TDC CRANK SENSOR – 8200647554/6
- WIRE HARNESS (Loom) - 8200673202
THERMOSTAT 8200772985
Top light sender unit/switch
TOP MOUNTS (SHOCK TOWERS)
(Suspension Mounts for above)(7701207806)
TOUCH UP PAINT 7711422243 / 7
UK 182 TROPHY REAR WING
- Brake Light for Trophy Wing
UK 182 TROPHY (Sachs Remote-reservoir Dampers)
- REAR SHOCKS each 8200519953 / 4
- FRONT SHOCKS each 8200514733 / 4
UNDER WHEEL GUARD/TRIM
- front 6000073747
( PLUS CLIPS x 3) (7703077435)
- rear 6000073749
WASHER MOTOR 7700430078
WASHER MOTOR TUBE - 7700665857
WASHER BLANKS pair - 7701209053
WATER PUMP - 7701473365
WEATHERSHIELD KIT - Part: 7711230495
WHEELS
- 172 Centre Cap
- 172 ph1 OZ F1 alloy 15’ - 6000073547
- 172 ph2 AUS OEM wheels 15’ - 8200135486
- 172 ph2 UK OEM wheels 16’ - 8200109001
- 172 Wheel cap KEY kit
- 182 CUP WHEELS - 8200342834
- SPEEDLINE ?? 15’ – 8200338257
- SPEEDLINE OZEDIA 16’ - 8200882274
- SPEEDLINE TURINI 16’ – 8200514737
- 197 17x7.5" SPEEDLINE WHEELS
Black 8200858947
WHEEL BEARING
- front 7701205779
- rear 7701463523
WIPER BLADES 172/182
WIND DEFLECTORS – Set of 2 - 7701410735
WINDSCREEN 7701066905
WINDSCREEN RAIN SENSOR – 8200063060
WINDSCREEN SEAL (x3) – 7701478235
WISHBONE
- RH 8200257957
- LH 8200257956
WISHBONE BUSHES 7700789477
XENON HEADLIGHTS (197) – All prices EACH.
- Headlights – 7701070489 / 7701070489
- Xenon Bulb – 7701046154 / 7701062188 OZ
- Balads – 7701209625
- Height Sensor 8200211900
- Height Sensor 8200630368
- ECU/Control 820029 4571
Bron:
http://wolfimports.weebly.com/rs-parts.html
Gr,
Kevin
