Hallo mede forum leden.
Weet iemand misschien of het mogelijk is om de voorkop van een Phase2 op Phase1 te monteren ?
Is dit 1-op-1 omwisselbaar of moet er nog het een en ander gebeuren om het passend te maken ?
Heeft iemand dit al gedaan of ergens gelezen (linkje?) die het wel gedaan heeft ?
Upgrade Phase1 naar Phase2
proportions
proportions
Re: Upgrade Phase1 naar Phase2
Hallo Polon,
What i mean is the front bumper + foglights + DRL from phase 2 in phase 1.
Here you can see the photo:
polon18
it fits without any problem, you have to connect the one extra wire from tail lamp to the DRL phase 2.
proportions
Did you do it yourself or have you read somewhere else who did this upgrade ?
If so, could you please provide me a link so i can see how it's done ?
proportions
But on the photo’s you still have the phase1 bumper and phase 2 headlights.
I want replace the bumper with phase2 like in the photo i send before.
polon18
I installed the bumper from phase 2 but I removed it because I did not want my phase 1 to look like all Clio IV phase 2. I still have a phase 2 bumper with LED fog lamps.
I just want it to be different clio
proportions
Thank you for the information.
Can you please explain the extra wire for the DRL ?
Can't i just plug the current DRL cables into phase 2 DRL's ? Why do you need an extra wire from the tail lamp ?
polon18
DRL phase 1 - two wires
1 GND. ( - )
2 led power supply ( + )
DRL phase 2 three wires.
1 GND. ( - )
3 front tail (position) lamp wire ( it's make dimming DRL)
1 GND. ( - )
1 GND. ( - )
- 10942 Weergaves
Laatste bericht door dick709
- 11712 Weergaves
Laatste bericht door jor74
- 16637 Weergaves
Trekhaak 7-polig naar 13-polig ombouwen
door Vertrokken: 16830 » » in Clio 4 Elektronica (vraag & antwoord) - 4 Reacties
- 5744 Weergaves
Laatste bericht door Vertrokken: 16830
