Bass Boost 0 / + 18dB
Enclosure Dimensions 50mm x 305mm x 305mm
Frequency Response 30Hz-250Hz
Fuse 15 Amp
Low Pass Filter 35Hz-250Hz
Max Power Rating (Watts) 300
Tuning Bass Reflex
Woofer size 10"
zijspeakers:
Compliance (Cms) 545.5
Cone Area (Sd) 5.2
D.C. Coil Resistance (Re) 3.6
Electrical Q (Qes) 1.196
Force Factor (Bl) 2.964
Free Air Resonance (Fs) 100.1
Frequency Response 75Hz-22kHz
Impedance (Nominal) 4
Magnet Structure (Oz) 5.4
Max Power (Watts) 120
Mechanical Excursion (mm) 7
Mechanical Q (Qms) 2.397
Mounting Depth 47mm (1 5/8")
Mounting Diameter 93mm (3-11/16")
RMS Power (Watts) 35
Sensitivity (dB) (1W/1M) 87
Total Loudspeaker Q (Qts) 0.798
4 kanaals versterker:
Bass Boost @ 45Hz -
Channel Seperation >50dB
Frequency Response (-3dB) 10Hz-40kHz
Fuse Rating 30A x 1
Input Impedance 20K
Input Sensitvity 0.2V - 8V
Max Power Rating (Watts) 600
Ratings per Channel 75 Watts RMS per Channel @ 4 ohms: 100 Watts RMS per Channel @ 2 ohms: 195 Watts RMS Bridged Channel @ 4 ohms
Signal to Noise >87dB
THD @ Rated Power 1% (1kHz)
Variable High Pass Filter 6dB / Octave
Variable Low Pass Filter 6dB / Octave
hoedenplankspeakers volgen nog: foto+spec's
