Clio IV stroom diagrammen
Geplaatst: 15 aug 2019 16:23
door proportions
Hallo mede forum leden,
Heeft iemand stroom diagrammen voor clio 4 of weet iemand waar ik die kan vinden ?
Wil graag beginnen met modden en modules ontwikkelen voor clio maar ik heb stroom diagrammen nodig om dit te kunnen doen.
Re: Clio IV stroom diagrammen
Geplaatst: 15 aug 2019 17:47
Euhhh... "Stroom diagrammen"? Als je elektrische schema's bedoelt:
https://www.clioclub.info/forum/viewtop ... 04#p387304
Geplaatst: 21 aug 2019 23:14
door polon18
which one diagrams do you need?
Geplaatst: 21 aug 2019 23:43
door proportions
I need the door wiring diagrams in first place.
Geplaatst: 22 aug 2019 01:11
polon18 schreef: 21 aug 2019 23:14
How about all of them?
Do you happen to have access to schematics and/or info regarding the CAN bus and the ECUs it connects? I am trying to figure out any differences between the ECUs in a Clio GT and in mine. I am willing to replace one or more ECUs if this fixes the issue of my partially dysfunctional RS Monitor.
And while you are at it, could you find out to which ECU the eco-pushbutton is connected and whether it is possible to change its function to "RS Drive", like in the Clio GT? I really wonder if the function of this button is solely determined by software.
Geplaatst: 22 aug 2019 17:09
door polon18
yes, I have the opportunity to enter to the Renault database and schemes, but unfortunately it is payable according to the Renault price list.
24 hours access cost my 30 € and counts not from the amount of checking but from the start. e.g. start at 8 am on Monday, end at 8 am on Tuesday and no matter if I used 5 hours or ten minutes
I pay it with an Australian credit card
Geplaatst: 22 aug 2019 18:34
Interesting... Is this service publicly available? Depending on the level of detail, €30 for 24 hours of unlimited access is quite affordable.
Geplaatst: 22 aug 2019 22:19
door polon18
No is not pyblicly available
but it doesn't work like downloading everything at once as a file. everything is in the form that everything is separate like the plug , diagram, description
If you want dors then is 3 files of one connection
Geplaatst: 23 aug 2019 10:15
door proportions
Mox, ik heb dialogys gedownload en als het goed is staan alle stroom diagrammen daarin.
Ik zal vanavond installeren en stroomdiagrammen naar jou opsturen.
Geplaatst: 23 aug 2019 12:36
Ik heb in het verleden ook diverse keren versies van Dialogys gedownload, maar de boel installeren en draaiend krijgen ging altijd uiterst moeizaam. Daarom ben ik ermee gestopt. Ik hoop dat jij meer succes hebt!
Geplaatst: 23 aug 2019 14:12
door proportions
Gezien mijn werkfunctie moet het wel lukken denk ik ..
Ben een systeembeheerder en applicatie ontwikkelaar dus het zou goed moeten komen ...
Geplaatst: 23 aug 2019 14:21
Mijn ervaring met Dialogys is dat ze enorm leun(d)en op allerlei Java-dependency's. Versies moesten precies kloppen. Ik wens je veel succes
Geplaatst: 23 aug 2019 19:49
door proportions
mox schreef: 23 aug 2019 14:21
Ik heb het gevonden , welke motortype heb je ?
Geplaatst: 23 aug 2019 22:39
door proportions
Eco knop: 1629
Diag aansluiting: 225
Stekker van Diag aansluiting:
Pinbezetting Diag aansluiting:
Geplaatst: 23 aug 2019 23:09
door proportions
Voor de gene die het ook nodig hebben, dit is de portier links (bestuurderszijde) inkomende kabel bundel (R153) :
Pinbezetting:
